paulb001
Registered Member
uuummm....right
Yeah. All of that. My rig is AWESOME but I'm kind of hamstrung by carburation!
Well, we lost @eagle mark::shovel:: because at this point, one of y'all should've learned enough to be so upset you haven't tuned in the last 6.5 years and want to do it for practice....for free....for me.....![]()
Tuning the MAF and tuning for fuel delivery is fairly straight forward. My hang-up has always been on setting the timing. I like to measure things and act on those measurements, not just fiddle around and see what sounds / feels best. Ideally a super high speed pressure sensor / spark plug combo to measure the pressure wave in the cylinder as the combustion takes so you can set your timing right at the peak would be my preference. Them things ain't cheap though!
An engine dyno with a load cell would be ideal as well, so you can hit all the fuel cells for real world data.
Then there are the other 10,000 variables in a common LS PCM all of which are super complicated and difficult to wrap your mind around.
gearhead-efi.com might be the place to ask.
Thirdgen.orgs DIY-EFI forum used to be the go-to, but it's probably pretty sparse on info anymore. But EBL has been around a long time, I remember it being announced over there, so there are probably some threads on it. I do recall it being appealing because it at least somewhat simplifies the process. If sticking with TBI, your tuning options are extremely limited, and not getting better.
The one difficulty I've worked through on the programming front is that there aren't (or weren't) any automated tools that you could use with Tunerpro to essentially build your tune for you as you drive. EBL might have that functionality, which would make it more appealing I think. Eliminating chip burning is huge, but if you are driven, and get your tune done quickly, it's kind of a hard cost to swallow IMO. Once you get the tune dialed in, unless you make hardware or drivetrain changes, you'll never touch it again. That's great, but as I recall EBL wasn't necessarily cheap, and for essentially one time use, it's a bit much. But I do see the value in it.
Best ROI is to buy a Civic for daily driving and keep the K5 for fun.The current EBL looks similar to hp tuners and you can program on the fly. But for $400 and downtime to have the ecm modded I don’t know if the value is there. If I did my math right going from 12.8mpg to 15mpg being able to tune, it would take about 11,000 miles for ROI.
Can you put a price on losing your soul?Best ROI is to buy a Civic for daily driving
