No it's 700r4 2wd....
Did you start a thread on your recording data,tune yet? Tuning a cam is time consuming. I will give you some comparisons of VE table from stock to a cammed motor. But all I have is Big Block stuff. I don't have a big cam SB tune.
First thing set your distributor to 5 degrees advance, change in chip. Clear codes and start motor, watch data for idle and it'll be rich, choose 400 rpm to 1200 RPM and 20 to 40 MAP. Use the offset funtion of TP and drop five at a time, watch data, still to rich drop five more, may have to add some timing in the timing table for the same RPM and MAP. Some guys try to get this right by dropping BPW but after you get idle you usually lean out WOT. Get an idle then work part throttle, then full throttle, then smooth. OK fuel is close now add timing till you find knocks, back off timing. Dave has a great SB timing table to start.
If you are having to much timing to make idle and starter kicks or engine knocks take out all spark at 75 to 100 MAP and 400 to 600 RPM. Make them all 0s and the truck will fire right up, you'll never hit those cells driving.
What I did with this last Big Block Mopar cammed with a BB Chevy TBI system was I start with a stock BB file, cleaned and flow matched injectors, 17 PSI (what calculaters said I would need) and a fuel pressure gauge I can see on hood. If it drops at all at WOT well fix it. Changed from TBI to TPI pump. Fix all mechanicals like bad connections at pump when I changed it, fixed three vacuum leaks, fixed grounds, fixed ignition on power to relayed supply as he lost spark when cranking, fixed a spark plug wire burnt and sparking on header, still had weird things happening and found batt termanals snugish???
That fixed my glitches.
I still have a couple hours smoothing tables and working on cold start with no throttle so I am at his house at sun up every morning. One or two more mornings and I'll have that done too. I'll have 25 hours into this tune, diagnostics and repairs. Guy is way happy since no one else has been able to make it run since he built it a 2 years ago... now it screams from a stop through first and second, that's 80 MPH and we are out of road. I can usually tune from there up to 120ish or 6000 RPM without driving. Then the only way to improve on that is with a Wide Band on a Dyno.
