I found the web page with information on this so figured I would add it to the tuning Sticky.Wonder if you know the math required to determine correct fuel pressure for a built engine? I had read somewhere you need to know approx HP and the size of injectors then you can determine the presure needed so said injectors put out enough fuel for engine?
http://www.megamanual.com/v22manual/minj.htm
