heres another website to explain common sense
http://www.babcox.com/editorial/tr/tr20244.htm
after you run your so called brake pad(friction material) over glass 1000 times, will it still be smooth? It will leave a finish that has the same ridges as the pad. And when a rotor has been removed from a vehicle. Will the rotor have "ridges" on the surface from the brake pad grooving it into the surface? And after a few miles, the brake pad surface matches the rotor in a perfect fit. But your "theory" is that a rougher surface is better. This will cause the brake pad not to "fit" into the rotors surfaces.
To make it easier to comprehend. If you were qualified, you setup the brake lathe to cut the rotor. It leaves 6 large points on the surface. Then you setup the lathe to cut finer(slower speed). This leaves 12 large points on the surface. Your theory, it is better to have the rougher surface (6 points) on the rotor because it "grips" more. In the real world, all the cuts are in one direction, so there is no better grip, because it was machined on a lathe. Because it has a "rough" finish. The brake pad will be pressing against 12 points on the rotor. Now what if we put a better finish on the rotor. Say we use 150 grit sandpaper on a lathe. This causes the points on the rotor to go up to 24. Now there are 24 points that the brake pad has to contact. Now the vehicle can stop in less distance because it is like having larger brake pads.
You can also use railroad track as an example too. the rails act as grooves like the rotor. The more rails, the greater the surface.
BTW, knobby tires have more surface area then slicks. So i dont know why you would want slicks for off roading. ??
