Check out the blue sea systems 5032
Its split so you can run 6 circuits on constant power, and 6 circuits switched.
https://www.amazon.com/Blue-Sea-Systems-Blade-Blocks/dp/B01BXTXV1Q
That’s the fuse box I bought.
Me too.That’s the fuse box I bought.![]()
I dislike that little junction block. I would just like to do away with it.I’m thinking about pulling my battery wire from the junction block on the firewall.
If you do that, what gauge of wire is feeding that? Is it still the factory 10 gauge? ( I believe that's what is in my '90) Maybe bump it up to 8 ga. ?I’m thinking about pulling my battery wire from the junction block on the firewall.
I just hate fusible links because there’s no quick easy way to determine if it’s fried without a test light and knowing which wire inside a bundle goes to what.If you get the right panel, you can run relay(sl on the panel itself, which just cleans everything up.
I'd be careful dispensing with the firewall junction block, the fusible links that feed it are important. (Having said that I ran a 10G + wire directly from my battery to an older style fuse panel, and I need to fix that)
Are there any fusible links out there (new) that are economical and available in a variety of wire gauge? Maxi fuses seem all the rage nowadays, but unless rewiring the whole vehicle, I prefer the unobtrusive fusible links.
Every time this topic comes up it tempts me to get a good aftermarket panel and redo the whole electrical system so there was room for everything on the one panel.
Nope. It glows when it blows. Haha.True, but how often do you pop them? They really only should be for catastrophic screwups lol.
Stumbled upon the Smartfuse by Fraron, running $170 euro, not what you meant though I assume https://www.fraron.de/en/power-inve...ramable-fuse-with-battery-protect/a-85859387/
Seems petty cool, I could see bolting that in right where the junction block is. Could even run a mini starter through that.
I don't really think about that as marine. I have just always used that for working on semis my whole career. It is definitely the way to go.Surprised no one has suggested marine heat shrink. It has adhesive that makes a water tight seal. I use it on all vehicle stuff.
Don’t you have to pull the bulkhead off at the firewall on the outside?On the interior fuse block, how do I remove it? I found 1 screw on the bottom left but the box still feels tight - what next?
The reason I’m pulling the box is because there are a couple of small unnecessary harnesses that loop around behind it so I’m assuming they plug in to the back side or to something behind it?
After spending a lot of time carefully trimming out dead weight I’ve reached the point where I’m down to a big bundle of junk that was for the TBI computer, DRAC and cluster. I’m hoping I can unpin the main plug and get it down to the column and exterior lights.
