I cut the wire and add a GM weatherpack connector. 2 wires in the same pin on one side.
That’s a cool option, I guess I need to study up on weatherpack stuff.
What is the best way to tap in to a wire without using a scotchlok?
Weather pack with a dab of silicon around the 2 wire seal. I have not had an issue in the past.
Do they require a specific to to crimp those itty bitty pins?
To be on the safe side you could always use that 20A ign feed to switch a relay controlling a larger gauge circuit coming from bat power for your new ign feeds. More involved but easily turns one ign source into many with no possibility for issues.As I work on the dash wiring I’m curious about a couple of things -
How does the fuse box come apart? I see one screw at the lower left corner, is that all? Does it plug in to anything on the back side or will it fall loose once unbolted?
I will be adding an auxiliary fuse box (6 IGN slots and 6 BAT slots). I found an empty 20a slot on the stock fuse box, do you think that’s adequate to power the IGN portion for items like choke, tach, MSD, alternator?
(fyi, I checked the MSD installation paperwork and it does not specify a power requirement for the switched IGN wire.)
Typical universal 30a relay or something fancier / higher amperage?Just your normal one unless you plan on some high loads. You could even go big and do a constant duty solenoid if you want some juice. https://www.amazon.com/Cole-Hersee-24059-BP-Insulated-Continuous/dp/B0064MX7USOh that’s a nifty idea!Typical universal 30a relay or something fancier / higher amperage?
Check out the blue sea systems 5032Blue sea comes recommended often, and if I had a better connection I'd check out what they offer.
I'm pretty happy with the way the Eaton Bussman setups are made.
I do not like being limited to ignition only power...if I need battery 12v, I dont want to run yet another panel. I also dont want more components tied to the panel (relays) randomly about. At some point things are going to fail, being able to easily test/swap/replace makes sense IMO.
Those are 35A relays, one of which is faux mounted to the panel. Mini fuses and relays save space.
