xj shafts
the XJ shaft comes from the jeep @ 23 1/4"
This is complete overall length, from tip to tip. As long as your needs are around 24" or smaller, you're good to go.
My total length after 1" body lift and new bushings 22"
Sounds like I should be ok but I'll go measure Monday to be sure. Do you have one on hand?
i'd like one too with the tack welded whatever, and if it's the longer one needed for me to eventually run a 1" body lift and poly bushings that would be great. 88 suburban so it should just bolt right in ?
Your 86 and 88 will work. My shaft is the slightly shorter of the two and works well with my 1" BL.
As of today, I have one available but awaiting payment currently. Will bump when I find more :waytogo:
got one longer one, specifics are in red, first post
found a bunch but only pulled this one, easiest to get at. Found nothing for myself :(
I need one for a 82 with no body lift, what do you got and how much ready to bolt in?
I would like an XJ shaft for my 87 which does not have a body lift. Please let me know price and availability for one of your bolt in modified shafts. Thank you.
Got two in today.
One long and one short. Please read first few posts to understand the difference and price.
I haven't welded either yet. Please let me know if you want it welded or you can do yourself. Thanks
I'll take a longer one, welded. Will send.payment this afternoon.
How would you like payment? I looked through the thread and didn't see a PP addy.
Ok, I'm sure a lot of us are curious. Could you measure the distance between the steering column side and box side? Butt the tape measure against the splined shaft and measure to the column side. No overlapping. I'll figure it out with my truck.
One "shorter" shaft left. I've been saving this one for my C10 but the truck isn't really going anywhere fast. (doesn't even have a column yet) It's already welded and ready to ship. The other two are already paid for.
If it will work for my 83 k10, no body lift at the moment but maybe a 1" later on, I'll take it. PM me a price with shipping to 96768 and payment instructions. Thanks
