- 1970
- K5 Blazer
- Standard
- Caged, corbeau seats, winters gated shifter, rugged radios intercom, removable steering hub
- Tilt wheel, tach dash
- Original 4bolt main bored and stroked 383ci, 11:1, edelbrock etec 170cc heads, edelbrock performer airgap/vortec intake, MSD pro billet/6al box, QFT 750cfm carb, fender well headers, Diy4x detachable cross member
- Original th350, Rebuilt and deep aluminum pan, hughs rv/tow converter, transgo shift kit
- Np205, rebuilt, Ord output seal housing, high angle driveline double cardan d/s upgraded to 1350s, offset 1310 u joint on front driveshaft
- Psc HO Saginaw w/remote res and agr fast ratio box, ord crossover, aftermarket pass knuckle, wilwood hydroboost master cylinder
- 4” deaver leafs rear with traction bar ADS 16” 4 tube bypasses, 6" tuff country soft ride leafs (temporary)14” ADS 4tube bypass shocks and king coil carriers, modified traction bar/Ord cross over, Diy4x detachable xmember
- Front d44 stock open, rear 12bolt with Detroit locker and moser axles,tube trussed, welded center section, lock rite
4.88s, Wilwood calipers all around
- American racing ansen replicas
- 35x12.5r15 General grabber
- Gloss black
High angle driveline double cardan 1350 shaft
1.7 MB
1.2 MB
2.4 MB
511.8 KB
2.6 MB
3 MB
1.2 MB
1.5 MB
1.2 MB
1.3 MB
1.1 MB
1.6 MB
1.6 MB
1.7 MB
1.6 MB
1.2 MB
1.5 MB
1.5 MB
1.3 MB
1.5 MB
2.9 MB
556.1 KB
634.4 KB
616.1 KB
669.9 KB
416.7 KB
519.5 KB
