Anyone know if the core supports are all the same for the 67-72 Chevys? I'm sure the GMCs are different.
The 67-68 are the same. 69-72 are the same, but that is how they split between years/grills.
I'm running CHEVROLET across the hood and would much rather not run the bow tie.
If you reach behind and push the ignition assembly against the dash, the bezel should screw off. Just make sure to keep the part behind the dash from spinning. You don't need a key to remove the whole switch.
It will tighten back up no problem
