1968 c30 "Papa Smurf" prerunner build. links, beams, and turbo
Wow that sits low in the chassis!
Looks great Nate!
Header clearance sitting that low in the frame? Zoomies?
Final fab and fitment.
Need to fab turbo hot and cold side
Few more engine cage pieces
Cab cage tubes
Back half gas tank area needs more tube
Trans x member and mount
Battery mounts
Gas tank mount
Dash and center counsel
Think that's about it. Once I get this stuff fabbed and mounted for fitment I'll tear the entire truck down 1 last time to finish weld, clean, and paint the chassis. Then time for reassemble, wire, plumb, and fire it up hopefully.
Can you fire before teardown to eliminate any engine shortcomings?
What is the purpose of that joint on your steering shaft?
I'm assuming your referring to the heim? If so when using universals in between every universal you need a fix point for the steering shaft to have stability. So my steering uses 2 sections of double d rod that are help with 2 3/4" Heims and a 3/4" fire wall bearing. And it's all attached using 3 universals. One of the gear box. One on the steering column. And 1 connecting the double d rod.
You can see most of it here in this old pic
oh, I see now. I didn't realize from the other pics that you had two universal joints. I thought that top one was just the end of your steering column which would have been a fixed point on that end.
Looks good. :thumb:
9" got painted with some Steel-it today. Ripped off the beams and steering to start prepping those and get a coat on tomorrow. Then too get fab work finished on the chassis by Saturday... hopefully
9" rundown
Ford housing
Nexgen 9" backbone truss
Ruffstuff disc brakes
Strange 3rd member
35 spline spool
4.88 gears
35 spline chromos
3rd member I bought complete from Ruffstuff.
EVERYONE will be checking this rig out at Dunefest....keep on it Nate!
