Too be honest, I took two weeks, along with waiting for parts to come in. All the ones I ordered have been installed. So, that has delayed update posts as well.
i did just get in the kickdown and throttle cables all with their brackets along with new gas pedal.
grille, fender (inner and outer) also cowel bolts just came in. I have to figure out what bolts go where. As usual with this aftermarket stuff. Nothing is labeled nor instructions on how. Battery tray just arrived.
i also need to get new headlights.
Oil dipstick
Wires need installing
Tranny cooler lines
Radiator +electric fans and hoses
Gauges( not sure if I’m keeping the original or going to Dakota digital). I’m not sure how to test if the old ones even work.
Transmission shift linkage.
Fluids..
then wiring the truck, plus rear light set up of harness install. Plus a few more items.
it’s already hotter than hell in AZ. Next week we get 115,117 so motivation to get in the garage will be hard to muster.
needed to get stuff done on K5 that I can’t do so $$ had to be set aside for that..
there is my June update.
in the meantime, a smoke and some Sabbath..
