I found an RPO decode on a similar truck and it says the "491 Two Tone Paint" means it was burnt orange and white.
Yes, and I could buy that it's "burnt orange". Definitely looks orange.Delete of the sliding window.
I’m curious of the factory color as well. Is the inside of the cab still factory color? That would be the top and bottom of the fender as well as inside of the bed
So it’s a Minnesota truck? CoolYes, and I could buy that it's "burnt orange". Definitely looks orange.
That’s how mine is, the cab top is the same as the middle of the fenderthe Deluxe Two Tone is the white roof btw
No that's just an example of what this one should look like before it was painted eggplant.So it’s a Minnesota truck? Cool
The previous owner of my 66 saved the build sheet that was under the seat when he had it reupholstered. That is supposed to be where you can find them on that era truck from what I understand. you can see the zig-zag of the spring permanently impressed on the build sheet. It's kind of a heavy duty paper stock like poster board.
I'm curious if there might be one under the seat of the 73 because it doesn't look like the seat has been worked on.
Per @Bent77 , yes it would have had the trim. Makes me wonder if they just glassed over those holes when they painted it eggplant. I was hoping the paint code would be on there.
I was wondering what the "rear window delete" is because it does have a rear window.
The last 6 digits of the VIN are serial numbers that I think were sequential so it might have been pretty late in the year.What month was that truck produced? Sometimes they got painted what would be the previous model year color
Was it @dremu who posted the propaganda sheets for these?
