But, but, I just got it running?!Might as well retire "Big Jim" now, he's got 2wd fever....
Fight the addiction Greg!But, but, I just got it running?!
While I have no answer for you, did you check the high speed fan relay?Anyone know why they don't list AC/heater controls for 1973?
I figured out when I put the fan on high it doesn't run at all. I was thinking about trying to replace the switch since the "chrome" is flaking off anyway. Then I was thinking about doing the entire control piece because the controls are hard to slide. I've looked on a couple sites and they skip 1973. They have a 69-72 and 74-75. They list the fan switch for 73-82. Why would 73 be skipped for the controls?
No, I will have to seek it out.While I have no answer for you, did you check the high speed fan relay?
It should have it, the '72 has it.
Finally going to have time to replace the brake pads this weekend. Planning to grease the wheel bearings too, probably hasn't been done in eons. Looking at the procedure, it's SOOO much different that the 4wd.
Now I understand why @GWeakland620 and @Kay86K5 are keeping their rigs 2wd......
