265s
I actually contemplated that.Embrace the C10 life. Big-n-littles. A little down hill rake works on those.
I did want a little more RPM so that was a factor. The other thing I wanted was a width better lined up with the wheels.I would go down in height just slightly myself.
But I would advise to remember the impact on revolutions per mile difference, if it is a factor for you. I'm not surhow much of a height difference you are looking at.
Now with 255/70r15, not a big difference.Need new tires and I'm thinking about stepping down from the roughly 31" 265/75r15 I have now to smaller 235/75r15. Any thoughts?
Told ya.Shorter tires make quicker launches.
I went through this once before with a motor that spec'd out of an 84 to use for my 77I haven't measured, but they "look" the same. I was thinking the difference might be the squirrel cage depth or how it locates on the shaft.
I haven't traced out the wiring diagram yet so I'm not sure.High speed goes through a relay correct? It does on my '72 and also in the eighties trucks. The switch turns the relay on for high speed or off to back through the resistor pack.
I have seen some blower motors that have a different hole diameter for the motor cooling tube, or whatever you call it.
