1973 K10 : Chloe
1973 K10 offroad build
Nasty, after running all through together, then individually, the Seafoan is so hot, i cant dip me fingers in it anymore.thats the mung from 8 injectors, that were cleaned on the outside with brake cleaner prior to the Ultrasonic cleaner with Seafoam...toxic waste, now.View attachment 419118
Looks like a crock pot.
Secret to a easy and successful
Injector R&R, red grease on the seals. Don't go crazy, just a thin film, enough to make them look wet. You'll get it in the hole, everytime.
☆Pin 85, is always ground.
☆Pin 86, is always incoming switched power, from what ever switch you're activating.
☆Pin 87, is Battery Positive, to be sent out on Pin 30.
☆Pin 30, is the common contact, which, in this case, is used to send power to what ever equipment is being energized.
☆Pin 87a, is not used in this particular application.
Finally got to work on Chloe, again.
I've had a splinter in my minds eye, about the whole A/C thing.
So, I decided to do something about it.
Chop, chop...weld, weld
I didn't get to finish. So...
You guys and your $300 A/C brackets, PSHHHHHH!
1 each, custom made knock sensor harness. 20220814_112927.jpgSpecial made for the custom knock sensor locations and different sensors on either side.
Finally got the clusterfuck under control.
Black terminal board is obviously grounds, Pink terminal board is Key On Power(Switched 12volts)
Red/White terminal board is Battery Power (B+,12volts)
I still have 5 or 6 wires to route, but, it is very close to finished.
The ammo can I mounted it all to, will also be used to house the PCM. Which I might add, is in the mail,on its way back to me, from LT1SWAP.COM
I paid $75.00 plus, one way shipping. I was treated very well, the owner answered all my questions, and was very kind.
More to follow, when it arrives...
