beags86
Eastbound and Down
Dislike *I gave ebke that big block awhile back.
There were a ton of differing opinions on that subject when I was looking it up. When I first installed I wired direct. But when I added the relay box I went thru a relay. if it comes down to and I have issues I can always change it to direct to pump later.Should be wired directly to the pump without a relay.
I haven’t gotten any further than that. It will light off but as soon as I release the key I can hear the starter grinding on the flex plate and it stalls out the engine. (Our atlas that’s my best guess to figure it out).It's way past tomorrow
Sounds like your 12v battery source is dropping. Is their a single wire feeding multiple relays/components? What condition is your battery?
I ran into some issues finding a clean source of power for FiTech when I fired it for the first time. I ended up going directly to the battery for the power source and directly to the fuse block for the 12v ignition source. No relays involved until last year when I added a switch panel.
that’s what I thought but the battery was staying steady. I’m trying to use it to fire relays for my electric fans.
but those shouldn’t switch on as they’re switched grounds to the relay from the fitech so it should be a massive draw off the bat.
Yeah but the key line is staying hot while cranking so that isn’t the issue
Sorry that earlier answer was for truckmans post not yours. We were posting at the same time so I didn’t see yours til after.I understand the orange 12v ignition source is ok but I’m asking about the 12v “battery” source (red wire) for the FiTech. You said that’s dropping voltage while cranking at the red wire right? That’s why I’m asking how that’s wired, what’s between the FiTech and the battery? Did you add relays there too?
