Sounds promising. I'm really hoping for you this time that you're good to go for a while now! You did clean out all of the coolers/lines right?
Learned this trick from David freiberger on YouTube, neat little spacer, hose routing with zip ties.
So i bolted it up without the converter seated right and it fell odd my jack to the ground...
RIP new trans.
No it isnt....
the converter wasnt seated into the pump all the way and i bolted the trans to the engine. it fell off the jack xoming down.
Nothing looks broke it looks OK but I'm afraid the pump is toast.
I don't have time for this crap, I'm overwhelmed with to much to do.
it's my fault, wiggling it back and forth wasn't enough and I didn't rotate it to the right and I thought 2 clicks was enough... I should brushed up on my knowledge but I was to excited to drive my truck again.
I'm kinda stuck in dog jail for the next couple of weeks - she just had surgery, or I'd willingly give you a hand. If you're still behind the ball on this in a couple of weeks let me know, I'll give you a hand.
Very much appreciate the offer. I will get it done and be out on the trails. I have gone to far to give up.
24 hours isn't enough time in the day I wish I didn't have to sleep...
