Im going to pull the pump and have the builder take a look and pray to god i didnt damage the pump. it wasnt forced hard at all.
going back an looking that the trans jack you're using (same one I have) I don't think I would ever try to install a trans with a t-case on it at once. It's just not stable enough for that unless you had a second set of hands helping.
it will go in fine but out is much harder... Oh well live and learn.
dude, I did the same exact thing. Thought I had the TC installed but when I got the trans in, couldn't rotate it to get it lined up that easy. I did get it bolted up, but when I started the engine, the output shaft wouldn't spin in any gear. I had destroyed the pump and the TC. Had to pull it again (by myself of course) and then I spent three hours trying to get the pump out with no luck. Finally took it into local trans shop, replaced the TC and pump and reinstalled. Very carefully this time.
I also balanced mine on the trans jack with the transfer case attached. Man was that a bitch on a sloping driveway. Almost got killed a couple of times.
Hang in there, all this will pass. During my build, my truck fell of the jack stands, I ripped my steering box off the frame, I messed up a trans pump, I bent push rods, and that is just the stuff that springs to mind.
I had mine fall of Jack stands, luckily the axle took the hit.
how far off was your converter from going in all the way? I didn't get that last bump in
I have proof!
Dropped a trans on the tork converter myself. But I did a good job and broke the pump
I have proof!
With that spelling it conjures up very different circular images. :deal:
:rotfl:
