Does not move enough. High misalignment spacers will cover that movement.
You know I'm not good at esplanin thins. I can build it all day.
Draw a vertical line on paper.
Now horizontal line at 90 degrees.
You have a shock and a le drawn.
Now draw a line from the intersection of those lines down at 20 degrees down from horizontal.
That point will be the bind. The tabs will hit the shock end mount. Steel on aluminum is not good.
You want the most rotational movement in line with the axle.
Not sure if that helps.
I will get pictures tomorrow of how not to do it.
Yep.
They do, but not for the price I'm getting them at. I love diy4x, but I'm running low on funds and need the penny pinch every bit!
I was a bit shy at first, but after talking to a few people I thought I would give them a try.
