Im saying screw inner fenders.
In my case anyway.
I still have inner fenders. Or maybe 60% of them. They protect the reservoirs for both the coil overs and the bypasses.
In my case anyway.
Description Mount your shocks or coilovers with this kit designed to be very universal. Made from the best components, here's a few features that set our kit apart from the rest -
- 1.5" or 1.75" DOM tubing (vs HREW welded that most use)
- Our kit uses shock bungs that allow the use of any shock mounting width
- .250" thick shock bracket resists tearing or bending
- Tube caps included to cap "frame spuds"
- Optional frame gussets shown below in 'related items'
- Gr. 8 Hardware included
- Extra long hoop legs allow for a wide variety of shock lengths
1/4". If you used anything thinner, it would defeat the purpose. On mine I made the plates. Cut holes in them big enough and oblong enough, to slide them over the tubing. Then welded the tubing to the frame. Then slid the plates into place and welded them to the frame and the tubing. if not, your just butt welding them to the frame or plate. It's a lot more work the way I did it.
Wonder if they meant stubs.I did individuals. But mine are spaced far apart due to the 2 shocks.
"Frame spuds"? Never heard that term before.
By "double plated" do you mean you welded another layer of steel over the frame? Kinda like you would with a weld-in steering box brace.I ran mine to the top of the frame. Double plated of course. Single bar above the engine. Then bar forward to core support and back into cab A hoop. Finally pulled the cross bar last September. Never new if it would come out. All it needed was a palm hit persuasion.
It's amazing where software is now, compared to when I taught AutoCad in 1991.
