You forget to use the strap on that Harbor freight tranny jack?
It broke off a few trans swaps ago. The dorman trans pan has a drain plug that isn't recessed like the gm factory one is so it was unlevel and slipped off.You forget to use the strap on that Harbor freight tranny jack?
Twice now, yesCase was already broken anyway right?
It wasn't very happy coming out and fell off the jack...
You forget to use the strap on tranny jack?
Honestly after the first five it has lost some of the zeal.You guys make these WAY TO EASY,
To paraphrase: Your tranny wasn't happy about coming out and tried to jump to it's death because you didn't have your strap on? Also, you apparently broke your strap on some number of tranny ago?
I'm kind of impressed in a way that you are managing to wear out a Transmission jack. That's not normal.
Level 2 rebuild kit with the raybestos z pack for the 4th gear. Borg Warner high energy band. Sonnax 2-3 shift sollenoid, sonnax actuator feed limit valve, sonnax super 4th servo, sonnax shift kit. GM Corvette servo and a beast sunshell. Also have upgraded 5 pinion planetaries over the stock 4. Looking at converters but might reuse mine I don't know yet.So it looks like you have new parts that can find the way into a new Transmission housing, what's the plan for the new build and install?
I think we need to get a pool going to see how long you can get this transmission to last? I'm leaning towards 1 year, but part of me wants to say you're going to enter into a longer term situation with this one. Dare I say settle down so to speak??????
This one will be the biggest... yet.
Same size? It might be tucked back?
This last one lasted 2 years I think? Internally it's fine just the case cracked and bleeds off the 4th gear. This one will be the biggest and best one yet.
