Quality never is.
If you want cheap, screw a nipple into tour tranny and slide rubber over it. It will eventually spew hot liquid all over the place.
LOL
Quality never is.
LOL
Did that on the way home from leaving BB15 :haha: That's what prompted the lines, now I just stepped it up a notch even more.
Ok I thought it looked familiar. Those are kinda like the hoses we used to make for replacing the copper bugle line on semis. It's the air line that comes off the air compressor. They have to withstand high temps. Factory uses copper with compression fittings. Replacement was a Teflon lined braided stainless. They had funky ends you assembled yourself.
I get the same thing for the POS Barnyard Buicks at work. But I have watched the guys at Parker assemble them sometimes. They are crimp style with the nut for stationing the line. Never had one problem, but theirs have a tighter crimp.
Which is why I believe that they did something wrong on Ben's line. And if they don't know, they can't correct their problems and Ben pays more out of pocket.
It's been sense 2015 I had them done, I lost the receipt and don't even remember which one I had it done at. Hose power or parker.
New parts came in the mail, I think I might be missing a fitting. Not sure being sleep deprived right now I couldn't picture it together looking through the box.
It's a steal braided line with a heat sleeve over it. I heat shrinked the end to make it more better.
Ran into a issue today, not sure how to go about this without doing two 90degree fittings, hopefully someone else has a better idea to go from under the core support to the cooler.
The 8an male to 6an female reducer at the cooler, that the 90 is attached to.
