For those of you that have used a Terminator X kit, do you have to run the vaccum line to the ECU for a non boosted app? I would rather use the stock map sensor.
No, you can do either, you can plug in a MAP sensor to the harness and tell the computer which one you are using, the connector is there. You may need an adaptor depending on which MAP you have.
Awesome, I have the adapter and will be using that! Thanks again, you have been very helpful to me. Not so much my wallet but helping out with questions... :haha:
I believe I saved you some in your wallet too had you bought the same elsewhere... :D
Just make sure you select the correct MAP sensor in the drop down in the setup.
Ordered the new alternator harness.
Next thing I need to figure out is gauges and dash, really wish someone would buy these autometers.
Put them on eBay...1 at a time...not a set...you can try a set first but I think they will sell better 1 at a time...
You finally got a combo that works!! woohoo!
Excited Music Video GIF by Train
Good point,
I still utilize the bumpers. That's the the hood pins are holding pressure against.
Good point, I will have to go through your build to see where you mounted them.
After looking at the link, I wonder if the cushion built into the pin would be able to act as the factory bumper.
