Well the shackle flip was on backwards and in the wrong holes... If my thinking is correct they should be in the factory rivet holes... I'm also thinking about putting my springs in backwards to re center the axle.
Is this the paint you used?
http://www.eastwood.com/the-original-chassis-black-satin-finish-set.html
Other then the rust peeking through, which I doubt I will have that problem in Arizona how well did it hold up? Do you have any pictures?
If rustoleum had a uv and chip resistant paint I would be all over it.
. I will say that it is very good looking frame coating and would be fine for a show car/garage queen and maybe in the Arizona desert but it was not a great rust preventative coating.What about that Rust Bullet stuff that everyone on CK5 used to use all the time? Is it good for painting that kind of stuff?
It looks like the original chassis black faded in your pictures?
what happens if you keep over thinking it.let me say a few words. . . . . . .
get it done ! stop over thinking and spending $$$
ask some of us old timer guys herewhat happens if you keep over thinking it.
