Glad to see you post Glenn even though it's a joke. Hopefully you are still following along.
Does bending the links weaken them at all?
Martin
Maybe a few degrees at best. I will have to think about how to do it, it has been years sense I bent conduit.
Different ype of bend. You need to find someone with tubing bender. Not a pipe bender.
Keep in mind that you are limited with how close you can place the bend to the end of the tube. The dies and strap will dictate that minimum distance.
Personally, I'd do almost ANY other option for clearance before I'd put a bend in a link.
-G
I see Ord did have this setup at one time. In the multiple versions they came up with.
Didn't he say the longer links only took off 3/8" of movement? Is that even worth it?
I thie said it limits it an inch of up travel, and makes it where the axle only moves 3/8 reward during up travel vs the one inch reward with the short links.[/QUOTE
Kind of, the axle moves 3/8 less then before so the extra length isn't doing much. I'm going to move the bracket forward back to where it was and play with link length with the PVC pipe. I'll find out what works and be done with it.
No way I can get it perfect I'll get it to where it works and be done. BB14 is coming way to fast and I don't want to take the Malibu.
I followed what ORD had step by step with the only difference moving the axle and steering box a little forward. Besides that, I can't think of anything really different?
The hoops came out great. I'll be at the shop tomorrow evening, so I can get some updated pics for you. It was close to being driven last June, but I bought a piece of commercial property, new house, got married, worked on new house before moving in, and working on old house for sale. To say the last 9 months have been crazy is an understatement :-) Now that things are calming down a bit, I hope to get it driving soon!!
