You looking for a receiver? Dunno if it fits, but I have a pretty clean straight one off my Blazer you can have.
Appreciate the offer guys, rather then trying to figure one out I just bought a class 3.
Time is tight and just wanted to move to the next thing.
Well, clean being that it will clean up. Its dusty.
I was actually looking for a draw tite,
Ugh, should I cancel and try to ship one of these? On my dime of course.
Well crap, it will be delivered tomorrow must be out of the az warehouse.
Sorry, I was a bit slow on that. If you do stop it I can meet you and hand it off.
Actually what I think I might do is just use bolts as stops, the head of the bolt should hold up the box.
Yeah, the plastic wears out on me too. I put a piano hinge on this, and then did a little piece of wire on one or both ends. This was a million years ago when CD changers were still a thing (now of course we just use a USB thumb drive.)
I think eventually I redid it with aircraft cable from the Ace.
-- A
If he doesn't, I might have interest. But it will be a good while before I can pick it up.
Unless 'ganoosh wants it, it's not going anywhere anytime soon. Right now it's holding down my patio.
Saying only 2 bolts in each side?
Need picture of said 3rd bolt issue
Yes only 2 per side, I 3rd hits the rivet on the rear cross member.
It started raining and I went inside, I don't want to get dirt in the diff, tcase or back of the trans.
All that stuff open to the elements?
Curious about the hitch. No way to move it forward or back?
My opinion, that boat isn't all that heavy, you'd no doubt be just fine with 2 bolts.
It isn't but I want to use this as a recover point with a shackle on the receiver.
Yes it is open, I think I might be able to move it back but it hits the exhaust.
I don't know if I'm doing this right but . . .
Tensile of a grade 8 bolt is at least 120,000 lbs/in squared.
X4 =480,000 lbs/in squared
Shear is 60% = 288,000 lbs/in squared
3/8 bolts = 108,000 lbs.
I still think you are good. But I've had a couple of Modelo's so . . .
