I was actually looking for a draw tite,Well, clean being that it will clean up. Its dusty.
Ugh, should I cancel and try to ship one of these? On my dime of course.
Well crap, it will be delivered tomorrow must be out of the az warehouse.
Sorry, I was a bit slow on that. If you do stop it I can meet you and hand it off.
Actually what I think I might do is just use bolts as stops, the head of the bolt should hold up the box.
If he doesn't, I might have interest. But it will be a good while before I can pick it up.
Yes only 2 per side, I 3rd hits the rivet on the rear cross member.Saying only 2 bolts in each side?
Need picture of said 3rd bolt issue
It isn't but I want to use this as a recover point with a shackle on the receiver.My opinion, that boat isn't all that heavy, you'd no doubt be just fine with 2 bolts.
All that stuff open to the elements?
Curious about the hitch. No way to move it forward or back?
That or weld it in addition to 2 boltsWhat about removing the rivet and drill the hole out for at least a 7/16 bolt.
