I did 2.5 quarts like it always takes.Just fill until it comes out the fill hole..
Correct, this is what I did took about 2.5 quarts.Fill the transfer case he is saying till it starts to run out of the case. Then you can stick finger or q tip in bent to see if it is 100% full.
Somebody say bent?Fill the transfer case he is saying till it starts to run out of the case. Then you can stick finger or q tip in bent to see if it is 100% full.
This thread is the worst roller coaster I have ever ridden.
I hope he wasn't talking about you! That's kinda weird...Somebody say bent?
All I can hear is the big clunk at the end
Yes, that is what i was trying to point out. But see aboveAll I can hear is the big clunk at the end
Jacked up the rear it spins fine. yes you are correct drive makes the noise. Reverse, neutral and first are fine. 2nd gear it make noise.I have to ask, are you sure that the rear differential is fine?
I know that it's difficult to tell from sounds, but that makes me think of gears skipping and the sound gets played in the driveshaft as well.
And I wouldn't think that when I try had the gov-lock, that it would cause the axle to try to lock up while going straight, without something getting into the pinion.
And that video seems like all you did was put it in drive, to get the noise.
