Just realized sense I built the truck I have changed the engine, 5 transmissions and a transfer case and the air cleaner still doesn't need cleaned.:haha:
Torque management off with the stock tune based on your driving habit is not how you should be running it. Talk to the 208 Motorsports guy, im sure he'll get your trans tuned properly.
My personal record for 700R4s is 6. I’ll prep the trophy for shipping.
If you want the lower first gear, there’s a 2.98 first available for the 4L80. Greg is the man to build one. Cry once.
David
Hmmmm, you sir are a bad influence. I'll have to look into that is this what you have?
No. It's still on my want list. I have a plain old 97+ 4L80E, which itself is a substantial improvement over most 4L60Es. It's a big jump, but the payoff in reliability has been worth it.
David
David
Good to know.
I might just do that for my suburban.
I have a 93 4l80e
Got a plan today to fix 4th gear, been reading up on it and I think I know what the issue is. I'm closing the gate at work in 5 hours then I'll head over to my storage lot...
Here is what I'm going to do.
All gears except 4th work and maybe a year or so ago I put a corvette servo in which you have to take apart the servo to do, I'm hoping the 4th gear piston o ring is leaking sense I still have reverse so I think the band is ok.
I actually looked to see if Reid made a 60e case. :haha:
I think this is a stupid failure... I'm still not totally convinced a 80e is the right choice this instance. This trans lasted 2.5 years with me driving the crap out of it... Yes a 80e would be smarter but I'm not putting down anything crazy hp wise.
A ten bolt is a good idea until you have destroyed four of them.
Why keep skimping on transmissions that keep going bad ?
Build the right one now so you never have to build another one again.
The thing is I'm putting the right parts in it and not skipping out. The failures have been user error or stupid reasons. I really think a 4l60e will last perfectly behind it.
