B
Bent77
Guest
$20 a pageFirst I asked how much it was going to cost because no sane person would do it for free lol.
THERE IS NO WAY YOU ARE WORTH THAT MUCH!!$20 a page
Guess we know who’s thread isn’t getting an index...THERE IS NO WAY YOU ARE WORTH THAT MUCH!!
@tRustyK5 ... possibly.
Cuz isn't the conversion rate a consideration?
For that I could have coilovers and bypasses on all 4 corners and make 500hp$20 a page
You could get one corner OR new cam and liftersFor that I could have coilovers and bypasses on all 4 corners and make 500hp
I don't think so Tim
A guy can dream right?You could get one corner OR new cam and lifters
don’t be dramatic
You missed a engine, transfer case and another trans.Page 1 start.
Page 200 LS install.
Page 250 ORD coil over suspension.
Page 321 first 4L60 failure. (following 60 pages of discussion how it failed and what needs to be done to fix it)
Page 453 second 4L60 failure. (more pages failure discussion, drive it like you stole it and question as to why did it broke again)
Page 542 trailer to BB, wheel
Page 592 third 4L60 failure. (further discussion on failure, cause and possible remedies to fix)
I might be off on the exact page numbers but anybody that has been through this have seen the pattern.
Just razzing. I'm just happy the truck has been getting more use and gaining confidence for longer runs. Stay at it dude!
So much I brought it back in 2018 with all one colorBecause you know it was worth it.
Metal shavings, assuming the wear band. It had some glitter on it, I wonder where the clumpyness of oil came from. I never hit it with shop air.Is that shavings or dirt in it?
Don't see any wear in the tube or anything. The shock didn't leak at all, was only down I think 30-70 psi of pressure. I don't remember if I set it at 200 or where king says at 150.Mine did not have any of that in it when I rebuilt the one I have done. Because of a bent shaft.
Raced shocks you see that and worse. Is there a wear spot in the tube? I rebuilt a set on a street driven truck that never saw very much movement. Worked a 3" area in the tube. Is the material magnetic?
