I'm pretty sure that's bent.
Cuz blue longbedWhy is @Bent77 under my truck.
Mine is bent exactly the same way and my plow truck is bent there too. People see this nice large hole in the crossmember and think its a good location to put a hook or a chain through to tow or pull from.Hmmm wonder how that happened, has always been like that.
You Know I thought but this all day and can only come up with one thing. When we were kids dad pulled a tree out with the truck and we never had recovery points or a tow hitch...Mine is bent exactly the same way and my plow truck is bent there too. People see this nice large hole in the crossmember and think its a good location to put a hook or a chain through to tow or pull from.
I unfortunately don't wheel the truck hard enough to get into those situations. Yes I have hit the bottom of the tank, but that was one time. The truck only gets wheeled "hard" in Moab. I'm just not interested in bashing the body up.The only time I ever had trouble when I only had 1 tank in the crew cab was doing snow bashing. A long day of busting drifts drank a lot of gas.
My troubles with the saddle tank was hitting the bottom of it and when fuel level was low enough a steep up or down angle would starve the pump. The starvation problem would happen with 1/2 tank.
But you are out in the boonies. Fewer stations close to you.I have a single tank in my c30 with a 454/4 speed and it sucks. 10 mpg or less. Constantly needs gas. I'll gladly swap to a bigger tank when I get time/money to do it. I'd do a 50 gal tank on the bed if I found one for a good deal.
There's like 3 in town 6 miles or so away. But it does use to gas just to drive over there to get more gas. Ideally I'd like to have bulk gas and diesel at the house for "farm" use. Going to the mountains for firewood or anything else burns the most gas. I could also really use a 5 speed swap.But you are out in the boonies. Fewer stations close to you.
