Not even a little bit now that you've jinxed yourself?
I don't believe in that crap. No, I'm not worried. Also, I have a hard time believing that my brand new poly motor mounts and trans mount are somehow going to wear out faster than that new poly mount on the back of the t-case (none of which have any drive time on them at this point) to allow enough twist in the drivetrain to cause any actual problems. The only time I've actually seen that is when people do a mount like this but never changed out there crappy rubber (or worn out poly) engine or trans mounts, meaning now you do have a lot of twist in the drivetrain which for sure will cause that issue. Or have a crazy amount of frame flex causing drivetrain flex with a mount setup like this too.
I just feel like the interwebs exaggerate these types of problems a lot and they are for sure a case by case basis, not a holistic "you have to do it this way" type of thing. I see the same thing with people's opinions online with how to build motors.
