fidelity101
OR!
Either I have the wrong combination of damper and timing pointer (they moved around a lot over the years)unless I am timing it off of #2, which fires 90 degrees ahead of cylinder #1. 18436572. #1 is driver's side, #2 is passenger side.
BUT!
well to avoid the dampener confusion I ordered a new harmonic balancer appropriate for this engine and vehicle model year(1985). They differ in part number from 86-91 and the 85 and earlier spec.
The crate engine came with 2 timing pointers but with the truck harmonic balancer being 8" it doesn't look like the other one fits at all. I can take a picture of both for clarification.
When I found TDC on cyl one I had the driver side valve cover off so I could see the rockers and make sure that both valves were closed at TDC 1 compression stroke for distributor instillation.
I'm so close I can taste it!! I need to get this ready ASAP so I can break it in enough because I want to haul the car for a 2 day event on the 20th and there is a wedding in traverse city this weekend that I have to stand up in so that weekend is shot :/
BUT!
