TheBeast_88K5
Banned
Nice...
nice work man, you're putting together one solid truck! trucks like this make me question the whole expedition rig theme for my suburban, makes ime wanna ditch the doors, A/C, etc and cage it.
You should have that thing out on the trail with us in no time ........right
Nice progressYou should have that thing out on the trail with us in no time ........right
I finally remembered to measure my front suspension (axle to frame) for comparison, it looks like I am right at 5" of lift. It is 13.25 ~13.5" from the bottom of my frame to the top of the axle tube.
Soo......any thoughts on when you hope to have it trail ready? I see Nick is looking to hit up RC again in September![]()
[jt512;3305616]I think Nicks springs definitely have more arch then mine, between the big block the front bumper and the fact my fronts are from a late model K5, they have hardly any arch to them.
Dont worry, I make it a point to provide Dan with motivation "regularly" to hopefully move the process along!Soo......any thoughts on when you hope to have it trail ready? I see Nick is looking to hit up RC again in September![]()
Took about 6 weeks from when I ordered them. Stephen from ORD designed these specific for my application. They are a 10 leaf pack setup for five inches of lift with the axle moved two inches forward. These are setup to use the factory mounts without moving them. They measure 48 inches along the spring and as they sit 44 inches spring eye to spring eye.
Looks like batmans rig from the rear.
Do it![]()
Sounds like you got it all worked out then right?
I was going to comment last night... but I was falling asleep as I was reading lol.
I got custom springs from ord as well. And also noticed the bad angles
My buddy works at a machine shop and made me some 5* shims. It was just a guess.
Worked great though. I think having my axle moved forward .5" and the face the HD shackles are longer than stock, all result in angling the pinion down.
I think a 6* will work awesome for you man. And I absolutely love this build
You can see the shim in this thread bolted to my wood blocks for spring cycling.
http://coloradok5.com/forums/showthread.php?t=306572&highlight=spring+cycling
