It has been a while since I've updated the thread...
I took the K30 out to do some truck stuff a couple of nights ago. A buddy just moved back to Denver and needed a hand moving his box spring and mattress from a storage unit to his new house. So, I offered to help with the K30...
We had a cold snap in Denver a day or two before I first tried helping him out. I primed the carb with fuel per usual and tried to fire up the truck. It cranked a bunch but wouldn't fire. I had the choke pulled all the way out and my foot lightly on the throttle. I tried again and it fired off but died - I guess I didn't have my foot on the throttle hard enough. After that, the battery died. I tried jumping it with my K5 and I
still couldn't get the engine to turn over. I took the battery to AutoZone to have it tested and charged.
A day later I tried again with the charged up battery. I got a few cranks out of the battery before it died again. My buddy jumped me and we actually got the truck to fire off and idle. From there we were able to successfully complete the mission - here are a couple of pictures:
At the storage unit, all loaded up:
At his place prior to unloading:
Anyhow, I was proud of it for making the trip. I also felt horrible about how little attention I've given this thing over the last couple of years. I am in a pretty good spot with my daily driver and the K5, so my plan is to park the K30 in the garage this winter and just work on it all winter long.
Here are my top 5 items in prioritized order:
1. Oil pressure gauge doesn't work.
2. Voltage gauge doesn't work.
3. Starter shims need adjusted (or starter needs to be shimmed)... I am getting the awful buzz sound more often now when I crank on it.
4. The carburetor isn't tuned / adjusted for Denver's elevation.
5. The steering is incredibly loose.
If I manage to fix those 5 items, I'll be able to start the truck more easily and will be assured that I'm not hurting it when I drive it. That's goal number 1... just want this thing to be reliable first and foremost.
My girlfriend's XJ is having a pretty bad fuel delivery problem, but once I get that sorted then the plan is to have the K30 take over the garage all the way until spring of 2023.
