I got to spend some time in the garage this evening and got the truck air filter base installed.
The reason I wanted to do this is two fold.
Firstly, the factory snorkle REALLY necks down and limits potential air flow.
Secondly the ThermAC heat riser port on the car base stays open all the time. The truck base has a two part system. One flap opens the cool air feed to the snorkle and there is another flap that closes off the heat riser port to help maintain and control the inlet temperatures.
Here you can see the original base and intake hose. It has a truck lid installed on the factory base in this picture.
The truck base has a built in spacer but it's not as tall as the factory spacer. I used a 1/4" plastic spacer under the base to allow me to clock out without grinding out the ears in the neck of the filter. This allowed me turn the snorkel from the passenger side to the driver's side to clear the AIR box and heater hose fittings.
I hole sawed holes for the IAT sensor and PCV vent breather in the proper locations and then sealed the old PCV breather hole with duct tape for the time being.
Then I was able to install the factory car lid and air filter as well as use some 4" drier vent tubing to hook up the cold air scoop behind the driver's side headlights. I had to put a vacuum cap on the old ThermAC supply port on the throttle body as well.
I was even able to use the factory heat riser tube from the manifold to the snorkle to help warm up the engine and maintain inlet temperatures.
Here you can see the factory snorkle and how it necks down at the tube that attaches to the scoop.
As it turns out, the truck base doesn't shroud the injector pod as much as the F-body one which should allow for more and better air flow into the throttle body.
A little test drive without any hard data makes me think it helped. IATs were better than I expected. No higher than 120°F idling around town and a cool 95°F on the interstate.
