Got some more things done this weekend. Finished filling up all the fluids in the truck including t-case and power steering...so all fluids are done for start up.
I also fixed my knock sensor issue. If you are going to run older big block headers on an 8.1, you will have clearance issues with the driver side knock sensor (found this out after I installed the headers...the knock sensor doesn't touch the headers, but there is no way to get a plug on it). So I used part#: 213-298 which is designed to go in a different location on the block (pretty much right next to the old location...you can look at the picture above to see the difference). So here is a pic of the new knock sensor in the new location
And this one if for
@skunked since I know he pointed this out a while ago....I also put these little sleeves over 6 of the 8 spark plug wires as most know, when putting headers on an LS style engine, you have some issues with the boots touching the headers. I didn't want to spend the money on new ceramic booted wires right now, so just purchased these to do for now until I get nicer wires (and I only did 6 cause there were one wire on each side that were not touching the headers at all, so didn't bother with those since this is somewhat temporary)
And I also finished off my clutch system. First off I purchased this little tube adapter thanks to a link from
@Russell :
https://www.swagelok.com/en/catalog/Product/Detail?part=SS-500-6-4&item=
So I installed the 95 NV4500 external slave cylinder and ran the 95 hydro line up to the 87 master cylinder that was bolted to the firewall already. I then took the hard line that comes out of the 87 master cylinder and bolted it up. I cut the two lines at a desired point I wanted the tube adapter to be at, and boom, this is what I had. I then filled the clutch system up with fluid and bleed the clutch...and there are no leaks and the pedal feels really good
So anyone else putting a external slave NV4500 into a square body....there ya go (thought it might be worth putting some pics of this cause this was one of the hardest things to find info on...so hopefully it helps someone else)
So, as of right now, it should just be wiring harness and that's it. Going to be out of town this weekend for the 4th, but next weekend going to see if we can get that knocked out and see if it runs!!
