Decided to take a break from trying to get the motor started and work on something I could actually see results. So started working on the rear lift. I also took a bunch of time to clean some things up and paint some stuff
This is all the crap that was cut off the rear:
2 and a half inch shackle flip from ORD installed, and their super shackles. Of course, the stock bolts were stuck in the sleeves, so had to cut/burn them out, so removed the factory bushing and need to get some greasable ones this week. So I will order those up and install them next weekend
And some shots of everything cleaned up and painted. And installed new flipped u-bolts to get rid of the old upside down ones
Just need to get the new bushings, install the bilstein shocks, and put the new break lines on and then rear is completely done....then on to the front...here are the front parts waiting to go on
