Actually I use these straps a lot.I did something I don't recommend after doing it. I used 4 tie down straps, the kind you just pull by hand and they have a cam release. I couldn't use ratchet straps because the ceiling is over 12 ft and those things run out of travel quick. So I ended up moving the stool around each corner while I picked up that corner and pulled the strap down tighter. I had to do this for each corner, and after each time round I would raise it a couple inches. Then repeat, again, and again, and again. Then the last few rounds I needed the ladder I had used to mount the 4x4s up there.
But after starting it, it didn't feel very safe, until I finally got the chains hooked up. But I couldn't let it back down reliably either. I will have to do something more secure to get it down when the time comes, because releasing one of those types of straps would not be smooth. Anyway, don't do what I did.
After I got the chains hooked up I ripped a 2x4 in half, and screwed a 2x2 on each side to keep it from spreading, with an extra piece on each corner to prevent it from sliding off. Figured that should be safer.
Remember that you only lower one corner at a time and the other three are still holding so the weight on that corner lessens as you lower it.I don't feel like it was safe. If one of those straps slipped the whole thing could come crashing down. I was the only one there and I didn't go under it until the chains were on, but I still don't trust it.
As of now I have no plans of when it will come back down, since I don't drive it in the salt, I plan to leave the soft top on indefinitely.
lol.
For the record.... A skid loader and some attachments would be a friggin RIOT on your propertylol.
Of course then you'd never get anything else done, cause you'd be out back moving hills and mowing trees or some chit every waking moment
At least that's were they'd find ME in that situation lol.
I am talking from experience and from theory.
You don't have to trust me but it's food for thought
I love my skid and attachments. I bought mine pretty much just for forks but it comes in handy with attachments all the time. The one drawback is a lot of the time you really need 2 people to move things around, chains, spotter, etc, especially overhead. That's the problem for all of us, all the time, you never have a helper when you need one.For the record.... A skid loader and some attachments would be a friggin RIOT on your propertylol.
That sounds like it should be in the pig pen...I do it all by my self pretty much always.
Just a lot of in and out
