1991 Volcano K5 - Family Wheeler - Fully Independent Twin Turbo BBC
How'd you get it up there?
The Rock Comedy GIF by Baywatch Movie
I did something I don't recommend after doing it. I used 4 tie down straps, the kind you just pull by hand and they have a cam release. I couldn't use ratchet straps because the ceiling is over 12 ft and those things run out of travel quick. So I ended up moving the stool around each corner while I picked up that corner and pulled the strap down tighter. I had to do this for each corner, and after each time round I would raise it a couple inches. Then repeat, again, and again, and again. Then the last few rounds I needed the ladder I had used to mount the 4x4s up there.
But after starting it, it didn't feel very safe, until I finally got the chains hooked up. But I couldn't let it back down reliably either. I will have to do something more secure to get it down when the time comes, because releasing one of those types of straps would not be smooth. Anyway, don't do what I did. :doah::thinking::rotfl:
After I got the chains hooked up I ripped a 2x4 in half, and screwed a 2x2 on each side to keep it from spreading, with an extra piece on each corner to prevent it from sliding off. Figured that should be safer.
You can install a rope and pulley system before you lower it back down. I'm using the Harbor Freight hand winch and it works great. Just flip the lever and crank up or down. When you do the math, you'll see it takes a long run of cable along a wall or ceiling to get the floor to ceiling lift.
My dad bought a Vevor brand ceiling hoist/winch from Amazon for like $200 or less. Got me thinking you could build a platform or something and winch it off.
Either that or modify one of those “tall garage lowering/raising” storage platform things I’ve seen around.
Actually I use these straps a lot.
They are safer bringing down than ratchet straps.
The problem is the same as you had lifting it up it has to be done a little at a time although you can do it easier since no lifting required.
If you do it once a year or less then I don't see a reason to change.
I don't feel like it was safe. If one of those straps slipped the whole thing could come crashing down. I was the only one there and I didn't go under it until the chains were on, but I still don't trust it.
As of now I have no plans of when it will come back down, since I don't drive it in the salt, I plan to leave the soft top on indefinitely.
Remember that you only lower one corner at a time and the other three are still holding so the weight on that corner lessens as you lower it.
I am talking from experience and from theory.
You don't have to trust me but it's food for thought
For the record.... A skid loader and some attachments would be a friggin RIOT on your property :waytogo: lol.
Of course then you'd never get anything else done, cause you'd be out back moving hills and mowing trees or some chit every waking moment :haha:
At least that's were they'd find ME in that situation lol.
For the top on dad’s bronco, we just slid some 2x4’s under it and bolted it down to those and then used eye bolts to secure rope to and then used a pulley system to pull it up. Simple and easy and secure.
