Has anybody here rebuilt a 3800?
What exactly would you replace and recondition?
I see that my other block has formed a little surface rust in the bores. If this cleans up with just some oil, I'm OK, right?
I would check clearances on everything. Mic the crank and compare to factory specs. Keep the lifters matched to their lobes and you should be ok using the cam if it mics good. I would put new performance valve springs in it if you are going to run it hard. Have the valve guides checked out and a good valve job wouldn't hurt. This would be the minimum.
When it comes to engine building, you can do as much or little as you feel like the gains are worth. There could be a little gain by smoothing the bowls behind the valves, intake and exhaust port matching, ect.
