Fixed my fuel system, fuel now goes in the tank properly. New filler neck, hoses, etc. and fuel goes from the tank to the TBI properly. All new lines / hoses, new fuel pump.
Paying for CK5 paid for itself again. I had fuel from the tank to the fuel pump, its mounted at the frame. Made noise like it should and check engine light acted like it should. Wasn't getting fuel to the TBI though. It would run if you put fuel in the throttle body. When I pulled the line at the fuel pump on the tank side I filled several gas cans, nothing on the other side of fuel pump. Some research here said even though fuel pump making proper noises it could be going bad. Bought a new one and voila'. When I took the pump out no fuel in the line this time. New one made same noises but I could hear the change when it started pumping fuel. 10 times of key on and off then hit the switch and purr like a kitten.
Short delay in message bear cub on my deck trying to get into my BBQ grill, yelled at it and momma bear stuck her nose through the deck railing.
