Too much "bitch fest"
Need moar 3D printed project pictures!!
voxelpla.com
I would guess 3D printed dimple dies can only last a few uses before they need replaced or something?I watch this guy on the YouTube. I just saw he sells 3D printer files for dimple dies and also an oil catch can. As well as some other things. Never though of dimple dies being 3D printed.
Weld Metals Online
The number one source for metal welding supplies, welding test coupons, welding kits, consumables, and great TIG and MIG welding machines from Fronius, PrimeWeld, and CK Worldwide! We are welder owned!weldmetalsonline.com
lots of bead rolling dies are plastic . depending on use the plastic holds up real good .I watch this guy on the YouTube. I just saw he sells 3D printer files for dimple dies and also an oil catch can. As well as some other things. Never though of dimple dies being 3D printed.
Weld Metals Online
I fought with getting good prints out of PTEG for a couple days and couldn't figure out the issue. Overhangs were just failing but everything else looked great. I finally swapped back from my 0.2mm nozzle to the 0.4mm nozzle and the material started printing perfectly. I think I had a partial plug in the small nozzle and wasn't doing a good job trying to clear it. But I did get good parts finally, just not with the fine level of detail I wanted for this small part.I jumped over to the dash cam mount on my Toyota to finish it up. Adding the small detail serrated lines to lock rotation required changing nozzles to the smaller 0.2mm size. With a successful test print in PLA, I jumped to ABS since I was going to be outside working, then aired out the house before the wife got home. But I won't be doing that again, it lingered a bit.
I'll need to make a externally ventilated space in the shop that can also be heated to do any more with ABS. I only tried one print since I had it on hand already and needed to wait a day for plain PTEG to arrive.
Today, I've adjusted some settings for better quality and I'm running PTEG.
I don't know if you think the HEPA filters take out anything other than particles. Your throught is scratchy from the fumes, you need to see what can if any filter these out.I plan to run any interior parts out of ASA because of the UV resistance vs ABS. I have designed a angled mount for my Holley ProDash that is a two piece sandwich style. I just need to tweak the dimensions.
However, I am at the point where I won't run PLA or PETG, or any plastic 3D print, without external ventilation either. I don't feel it's safe after getting scratchy throats and mild headaches from PLA even with a HEPA filter on the exhaust. I think a lot of the fumes come from the purging. I plan to put an enclosed purge container on the back instead of the chute.
