If you want, a .25" X 1.5" piece of steel hammered and formed can be welded to the outside of your diff cover to protect the ring gear. I would incorporate something to keep the bottom holes on the rear flush so the rocks can't peel it open
If you don't buy a cover, reinforcing that one before you grind is a good idea. Never got mine to stay sealed without protection on the lower 3 bolts. I also used header bolts. Wasn't much left on the bottom when I sold itI usually grind the bottom of 14 bolts smooth but didnt on this one. I might get under there and do that during some down time waiting on the rear driveshaft.
Now I have no actual proof, but more than once it has been suggested that there is more lift compared to stock because the stock springs are sagging more than we realize.I take it you didn't move the axle forward any? I have the same springs and zero rate and plan on moving the axle forward 1.5, can't find a straight answer on which crossover will work. Guess i'll just call ORD monday and talk to them.Stock push pull with ORD steering brace and ORD drop pitman arm. Not looking to do any hardcore rock crawling just trail riding around the Rockies. Didnt want to spend the money on cross over at the time. Hopefully I dont regret it.
I did the same thing.No axle stayed put in the front. I only moved rear axle back.
looks good to me. Plenty of room for flexing. Might want to double check your droop on the front, that's a lot of lift for a stock d-shaft.
