5.3L Toyota 1994 FJZ80 Land cruiser
Did you compromise any axle up travel by setting engine lower?
Nope. Just had to run the f body oil pan and I will either have to notch the tranny pan or run a f body one.
Yes, all russell stuff. The pump is 5/8 o-ring to - 6, the gear box is 5/8 flare to - 6. Then a straight and 45* going into the hose. With russell power steering hose. I can look at my part numbers and post them if you need them.
Gotten a little more work done. Getting the shifter cable worked out really kicked my ass. In the I barely won! Here are the pics though.
The cable mounted up high and tight
I've read the stock lower control arms can't take a hit, so I cut them in half and sleeved them with 2" x. 120 wall dom. Ran 8 spot welds down each side, plus two in the middle where the stock tubes meet up. I also ground down the factory weld and notched the 2" out so I could tig it to the joint itself also. uploadfromtaptalk1434648721210.jpg
Also built a computer mount. Back in the passenger side Corner. uploadfromtaptalk1434648877043.jpguploadfromtaptalk1434648901733.jpguploadfromtaptalk1434648928400.jpg
Got these in last night, front one is on the way, just shipped separately for some reason.
