Alan2smiley
I'm in the shop
I have a 4BT, 3200 gov spring, NV4500, 4.10s and BFG AT 12.5 37s with tail wind down hill I can do 90 MPH
I have an '84 CUCV with a '93 12V Cummins, Getrag 5 speed (way better than people make it out to be!).
With 37" BFG' A/T's and 4.10's, 70 mph is ~2000RPM,
If i ran empty all the time, I might consider taller gears. I tow my buggy on a car trailer and I feel this setup is perfect, wouldn't change a thing.
tho a dash job is about eleventy7 on the list at this point.. behind a kennel, of ALL things...
im working on making the big truck 4k rpm tach work off the p pump crank signal. Not finished. I want a tach to showoff that I have a gm diesel tach in my truck. no other reason.
I think I'm just gonna eventually do a slight revision of my K5 one.. full Autometer Pro Comp-y, Ryoken red trim-ringed, kinda deal..
but I need to do the rest of the interior/kennel first..Stewart Warner full Sweep diesel tach. Added a stud on the alternator, works good. If Had to it again would of got with the Hr meter.
SLOW DOWN!!!
wait
i didn't even see that...
135Hp won't let me slow down! I put in a 100mph speedoother gages are factory 6.2
), fuel level.... oil pres, water temp, pyro, boost... ????? fuel pressure? oh, air pressure for the York!!!!!
