twojoints444
Registered Member
I welded up the shifter to "cure the sloppy shifter" but i think i fu*ked up. I welded the broken spot welds and around the "ball", and i welded the "pin" at the bottom that goes into the shift rails. Now with the top cover off the transmission i cant move the shifter at all to get to the neutral reverse "sweet spot" to get the top cover back on. Did i fu*k up by welding that "pin" at the bottom of the shifter???
Heres a link to help explain. LOL.
http://www.pirate4x4.com/tech/billavista/sm465/index.html
