Block got a little cosmetic work done tonight.
Amazing how neon it looks when freshBlock got a little cosmetic work done tonight.
It was still wet when I took the pic.Amazing how neon it looks when fresh
Uh-OH!!!!
Looks like the can says it's only rated up to 500HP!!! That's not going to be good enough...
-G
Dammit! I picked up the wrong can.
Finally showed up....
Specs?
Full specs for the 496.... Heath was a ton of help here:
Mark IV 454 4 bolt main block bored to 4.310"
Rotating assembly:
Scat forged crank (4.25" stroke)Brodix Race Rite BB-O (115cc combustion chamber, set up for solid roller cam)
Scat forged H-beam rods (6.385")
Mahle forged pistons (18cc dome, 2cc valve relief)
Comp solid roller cam 11-771-8:
Duration - Intake 280* Exhaust 286*Edelbrock dual plane intake
Lift - Intake 0.646" Exhaust 0.653"
Lobe separation 110* (it'll be lopey)
Static compression 10.25:1
Dynamic compression 8.17:1
Then the torquing fun commenced. 110 ft/lbs in 10 pound increments. I was beat by the last one. But the crank turns smoooooth.
I think the dyno sim is wrong.
No way that engine is less then 600hp.
Interested to see how the heads do.
I think they might be a limiting factor here.
Really no reason to spend that kind of dough to build that beast and then cheap out on 5 bills for legit numbers. Plus optimize your air/fuel/timing.
I dyno'ed my 406 once finished and found made the most power at 38degrees. I would have never put that much into myself....
Forget old school snug down ring compressors. These guys are the way to go. Ridiculously easy and way smoother. Wish I woulda stopped to get a pic of one going in...
Buttoned it up with the timing cover, oil pan, and freeze plugs.
Now we wait on Brodix.
Copper coated the head gaskets, set the heads in, and torqued them down. Long block done. Looks damn good.
Poured some ZDDP over the cam and lifter galley. Added some assembly lube and dropped in the lifters
Ordered up some lash caps to protect the valve stems from mushrooming. Those'll be here in a couple of days, then I can put on the rockers and measure for pushrods.
The engine looks awesome! Those timing bolts are going to rust, nevermind, you live in TX.![]()
Speaking of that, did you check your P-V clearance?
The engine is looking great AJ, nice work, it's going to run real good! You buy extra tires yet?![]()
No we didn't check the piston / valve clearance yet. That's on the list for this weekend.
I'm planning on pretty much blowing all the rubber off of these tires. Already have the next set in mind.
Did you check the cam endplay? Might need to shim the buttom or file a little off of it for it to be perfect. Or you can always dent the timing cover a tiny bit.
What kind of tires you going to?
We did check the cam end play. It was just under .010"
Either BFG MTs or ATs possibly in the 37" flavor. Still deciding on wheels. The 16" wheels will get sold for either 17s or 18s.
