'72 K5 - AJ's Gray Matter Build
Block got a little cosmetic work done tonight.
Race Rite BB-O. 115cc combustion. Big oval intake ports. 270 intake volume. 2.25" intake, 1.88" exhaust valves. 1.550 Roller Valve Spring – GA 1000, 0.700 Maximum Lift
6/4/16 - The long block - Got a good days work at the shop yesterday.
Started the day off feeling kinda studly.
Copper coated the head gaskets, set the heads in, and torqued them down. Long block done. Looks damn good.
Solid rollers
Poured some ZDDP over the cam and lifter galley. Added some assembly lube and dropped in the lifters
Ordered up some lash caps to protect the valve stems from mushrooming. Those'll be here in a couple of days, then I can put on the rockers and measure for pushrods.
Full specs for the 496.... Heath was a ton of help here:
Mark IV 454 4 bolt main block bored to 4.310"
Rotating assembly:
Scat forged crank (4.25" stroke)
Scat forged H-beam rods (6.385")
Mahle forged pistons (18cc dome, 2cc valve relief)​
Brodix Race Rite BB-O (115cc combustion chamber, set up for solid roller cam)
Comp solid roller cam 11-771-8:
Duration - Intake 280* Exhaust 286*
Lift - Intake 0.646" Exhaust 0.653"
Lobe separation 110* (it'll be lopey)​
Edelbrock dual plane intake
Static compression 10.25:1
Dynamic compression 8.17:1
Don't give me any credit, you picked everything out yourself, I just helped confirm your dynamic compression was right with the heads, cam, pistons and rods. But the engine is all you, you picked the cam, the heads, already had the intake, etc. You really wanted a solid roller, which is actually pretty mild for a solid roller, but should run real good.
Then the torquing fun commenced. 110 ft/lbs in 10 pound increments. I was beat by the last one. But the crank turns smoooooth.
10 lb increments is a little overkill, that is a lot ot torqueing! 3 steps I what I usually do, from the middle out. I would of gone 40, 75, 110 after snugging them up with a 3/8" ratchet, which is kind of like 4 steps I guess.
I think the dyno sim is wrong.
No way that engine is less then 600hp.
Interested to see how the heads do.
I think they might be a limiting factor here.
I agree with beags, I think the dyno sim is wrong too, the torque is probably a little high on the low side and your hp may be good or might be a tad low, depends on the tune.
Although with that cam and intended RPM range I don't think the heads are a limiting factor, they flow enough for almost 700 hp and should have very high port velocity. If you were revving it higher that might be different.
Really no reason to spend that kind of dough to build that beast and then cheap out on 5 bills for legit numbers. Plus optimize your air/fuel/timing.
I dyno'ed my 406 once finished and found made the most power at 38degrees. I would have never put that much into myself....
You would of done the same thing at the track, 38 degrees is where I had my old small block at after a few test passes. My uncle always says, "you can't take a dyno down the track". Plus way too many people dyno stuff and then install it in the car completely different such as the headers, air cleaner, fuel system, exhaust, etc. Dynos are great if you want to learn numbers, but tuning it in the car at the track is what really matters, and thats what you feel. Plus with his EFI being closed loop his A/F is going to be pretty darn close.
Forget old school snug down ring compressors. These guys are the way to go. Ridiculously easy and way smoother. Wish I woulda stopped to get a pic of one going in... :doah:
Buttoned it up with the timing cover, oil pan, and freeze plugs.
Now we wait on Brodix.
Those ring compressors are awesome aren't they? I switched over to using them too, I like the total seal units, a long gradual taper, I ruined a set of rings using one of those wrinkle band compressors, scratched the rings all up because of wear at the ends where the clamp connects. I shot that thing, literaly, blew it to pieces with a Henry lever action. The thing is, if the piston to valve clearance on that motor wasn't too low, so I had to take it back apart again, I would of never known the rings were damaged. Then you try one of those one piece tapered units and start laughing at how easy it is.
Speaking of that, did you check your P-V clearance?
The engine looks awesome! Those timing bolts are going to rust, nevermind, you live in TX. :pimp:
The ZDDP isn't required with the roller cam, but can only help.
I don't think you need lash caps these days, I would only run them if you need them for clearance.
Did you check your camshaft endplay?
BTW, if you have any trouble getting the rockers on the center of the valve, the Dart adjustable guideplates work awesome. Obivously the corrrect pushrod length will get your rocker geometry correct. But sometimes you can't get the roller centered on the tip with both rockers in the pair because the quidplate is one piece. Well, the Dart guideplates are two piece and they work excellent. Highly recommend them.
Also, don't forget to check the pushrods for clearance to the head, sometimes you get some that rub and you need to clearance the head with a die grinder.
The engine is looking great AJ, nice work, it's going to run real good! You buy extra tires yet? :thumb:
In Texas......he should spend more time worrying about getting a snorkel that will work on that setup!!!
-G
No we didn't check the piston / valve clearance yet. That's on the list for this weekend.
I'm planning on pretty much blowing all the rubber off of these tires. Already have the next set in mind.
Big, smoky burnouts pretty much guarantee a gold medal podium finish for MPS....
:waytogo:
-G
Did you check the cam endplay? Might need to shim the buttom or file a little off of it for it to be perfect. Or you can always dent the timing cover a tiny bit.
What kind of tires you going to?
We did check the cam end play. It was just under .010"
Either BFG MTs or ATs possibly in the 37" flavor. Still deciding on wheels. The 16" wheels will get sold for either 17s or 18s.
S
Sounds perfect, the annoying thing about the cam endplay is guessing how much the gasket will compress when you tighten everything down.
Tires sound nice, those will be expensive to roast.
