For those welds that end up "uphand" (first pic) to make your life a bit easier next time just tip the monolith up until the area you are going to weld is flat. Ideally a corner to corner prep is flat when the root is at the very bottom. This would have entailed a fairly difficult rotation of the part X4 though. Simply raising one end however would have at least put those welds into the horizontal position which is a ton easier than even slightly uphand.
As for the complexities involved in the heat/shrink game...it can be quite challenging. The more you do it the easier you 'see' how and where it's going to want to pull. Getting it right is quite rewarding. Good job! :waytogo:
Looking good Greg, I was having trouble seeing how the monolith was going to come together early on, but its making more sense now.
A few more hours....... a bit more progress:
Extended the "X-brace" to the very edge of the baseplate, then capped it across to the heim pocket. At that point, it made sense to plate across the rear heims from the top side.... using rosette weld technique. This effectively "locked" all of the smaller components together strongly.
Flipped the monolith over and welded it again from the underside to add even more strength beyond what the rosette welds could provide...
Finally.... spent a few minutes dressing the welds on the front heim hangers. The welds were a bit "blobby" from my attempt to weld uphill on the corner-to-corner joints. The new smoothed edges look a bit more professional.... I think. :waytogo:
-G
When I can I acutally prep my weld so I can grind some of it off to make it smooth.
I know most like the look of a pretty weld, but I like it better if it looks like the piece was molded out of steel in one shot.
Sometimes very hard to do though, so most of the time I just leave the welds.
Greg, I sure hope you have many more mounting holes planned for this monster, I mean monolith. :D
You smoothed those out really nice... :waytogo:
And your shop is a mess.. :eek:
That's all I got. :tongue1: :wink1:
....and it's cold too. :D It was 46 degrees inside the shop last night. I finally had to light the pilot on the LP space heater for the winter season.
Most definitely.... two holes per side isn't going to cut it. I am still trying to figure out the best way to drill holes through the boxed frame (and the monolith) in the spots I want them and insure that the holes stay perpendicular to the frame. A magnetic base drill would be great to use....but I don't have one.
For now I can use the holes I've got, and when I blow this whole project apart later on I should have better access to get the new holes drilled....and to install all of the thick DOM bolt sleeves as well.
-G
I do too, including purposely over-running the stop starts so they can be dressed down later.
Lookin good Greg! :waytogo:
2013.11.04 - UPDATE! - THE HILLBILLY CNC MACHINE....
It was a mix of good and bad this weekend in the shop.
At the point were I left off, the monolith was completely plated-up for the rear suspension heims, so the only remaining item was to plate the front hangers a bit more, and then drill some speed/drainage holes. Things were getting pretty close to completion, and truth be told I'm getting a bit bored with the monolith project now and will be happy to move along to something (ANYTHING!) else...
The front hangers needed a tricky set of top plates to help strengthen and triangulate the vertical bracketry. You can see them in this photo.
This helps tie the plates into the side areas, and into the long "X" structure that runs all the way through the crossmember. With a couple of small boxing plates, the areas are beefed up and are now sealed from the elements.
With everything tacked in place it was time to rotate the monolith into a more favorable position for corner-to-corner welding. As Rene astutely pointed out, if you go to the trouble of getting the weld horizontal and keep the deepest part of the weld at the very bottom it becomes MUCH easier to lay down a good weld and you don't end up fighting the "sag" in the puddle.
Things were going great, and I was laying some nice beads using this technique.... then as I was finishing up a short welding pass, the welder completely QUIT. Nothing.... no spark, no puddle.
I thought I must have boogered-up the contact tip and fused the wire to it accidentally, but on closer diagnosis I found this instead.
Yep, it's official. I've now run throught my SECOND 12.5 Lb spool of .030" wire since this project began! :doah: :waytogo: It's a weird "badge of honor" type thing I suppose.... getting that much trigger time means that I'm really working hard on the project and getting a lot more experience along the way, but unfortunately I didn't have an extra spool in the workshop to reload with... so progress came to a screeching halt.
Since I still had several hours left in my workshop day, and the space heater had the shop at a comfortable 60 degrees (outside was roughly 30 degrees) I decided to come up with a solution to drill my speed/drain holes in the monolith bottom plate..... It's not sexy, but here's how I did it.
Basically, I just walked the drillpress out into the middle of the shop then pushed my workbench underneath...then cranked up the table so that it acted a little bit like a vise to hold the press a bit more firmly....
The result was only OK. I'm using the 2-1/2" annular saw which is a pretty big load on my low-end drillpress. They really aren't designed to cut through 1/4" plate either. I tried WD-40 as a cutting fluid, then moved up to my tap oil...and eventually settled on regular old motor oil to try to keep the heat down and keep the cutter from binding and locking up once it got about 1/2 way into the plate.
At this point, I've got a lot of partially drilled holes, and it may be easier to try to finish them from the opposite side using the existing pilot holes as an index. I think there is just too much friction on the sides of the cutter when the cuts get too deep..... :thinking:
Anyway..... I ordered 2 more spools of wire (I'm finally learning!!!) and 20 more contact tips just to be safe. I'd better get to my local AirGas and refill my 80cu ft gas bottles too while I'm thinking about it...
-G
-G
something i saw that might help with your hillbilly machine.
there is a vendor on pirate that makes an underdrive kit for those type of drillpresses. might help to slow the speed down some on such thick material.
If you find a link please post it.
This one runs at something like 600RPM as it's slowest setting....still WAY too fast for this type of metal cutting.... I think <100RPM is where I should be.
I assume you're talking drillpress though, right?
-G
Greg try flipping that beast of a crossmember over and finish drilling the holes from the other side, if you have room.
-G
hes already ahead of you LOL
Now that you have the holes partially cut, could you just use them as a guide for your plasma cutter tip? Might not be as clean, I suppose.
Greg this build is simply amazing. Spent most of the past week reading from page one any time I could. The amount of skill/craftsmanship/patience that you have is crazy. Keep up the awesome work!:waytogo::bow:
Still thinking it might see daylight before snow starts flying?:whistle:
Thanks for that link. Looks like I have something to put on my list for Santa this year.... :D
Yeah, I think that would be a splattery mess. I do have a bunch of those little drum sanding rolls for my air grinder to clean up the holes afterward, but I'd probably spend 8 hours cleaning up the holes to make them look good... :doah:
I don't know man.... It's well below freezing in the mornings these days, so all it takes is one freak event and we'll be blanketed in snow. Looks like your already have a storm coming your way in fact.
In reality, I've got to finish the monolith and install it (couple more hours) but I still have to design and build the frame side upper link mount as a permanent and beefy version......AND design and build the front strut upper hangers too. It's actually quite a good sized list as I think about it. :whistle:
The good news is that as the holiday season approaches I am taking off quite a bit of time from work... So even though the weather might not be great, the progress should be good.
-G
